Hello all. I'm wondering what method guys are using to get a good finish with a sprayer on a 5 panel shaker style door. I have about 30 to paint and want to get a nice finish. Here's what I'm thinking. I will use the screw and sawhorse system to lay flat. I will vacuum and then prime with BIN shellac based primer. Should I then sand the surface lightly with an orbital sander or a regular palm sander. Vacuum again and then spray each side with Benjamin Moore aura satin. I'm planning on using the Graco 395 which I will practice my method on individual doors before setting up a few at a time. I have experience with the handheld graco models but not with the 395. If you know of any videos which highlight the method to spray doors with the angles of a shaker style door that would help. Also, I'm open to suggestions about modifying my choice of primer. In my experience it goes on very easy and dries super quick as well as super flat (no texture). It also sands very easy. I'm not super familiar with the screw/sawhorse setup so any info/ videos about that would be appreciated also. Thanks!!
