1 - 20 of 30 Posts
Painting Contractor
We have 2 - 24' aluminum and 2 - 32' aluminums. The 32' aluminums are pretty heavy as is, I can't even imagine trying to carry the fiberglass. I actually droped one of the 32' onto our van when we first got it, from about five feet above, wasn't used to it yet, glad it wasn't the customers house. :eek:
I am a big fan of our aluminums they support a 12' - 18' plank and ladder jacks very well and I feel very safe on them. Then again I only weigh about 150...
We only exclusively use Werner ladders also. I believe they are the best ladders on the market, aluminum or fiberglass.
Painting Contractor
brocknoland said:
Any expirence with the Little Giant?
http://www.ladders.com
I have heard good things but I am skeptical.....
The guy from Tool Time in the video sold me... No but seriously, thats a pretty expensive ladder and the coolest thing it does, the scafolding, you need 2 of them for.
I know a carpenter here in Milwaukee who has 2 of them and he seems to like them.
Back from the dead...
For clarification:
We only do interiors, w/c and paint. So our largest ladder is the type 1a 24'. And yes, it is a heavy sucker. I wouldn't want to move around a 32' for exterior at all. We use only Cuprum, Green Bull, or Werner. None of that cheapo Husky crap HD is pushing right now. Anytime we use anything over 16', 2 men are required on site for safety reasons.
As for the Little Giant, it does all it says it can do, but is pretty heavy to tote also.
I dont care for Little Giants. To me it seems like they try to do a lot of jobs, and none of them well. They weigh a ton and as they age the pins are knuckle busters. To me, a werner medium duty ladder in the right sizes for the job, with a werner Sta-Safe stabilizer for each is alot better setup than a little giant. The little giant seems to weigh about as much as a 24' or 32' Werner.
I don't like aluminumum's because it's difficult to spell LOL and there is always the power line issue. Consider the fiberglass a gym that you don't have to pay for, I'm in my mid 50's and you don't hear me griping about the small stuff.
I like oiur 28' aluminum's since they are light weight and easy to manuver, BUT I hate when we have them extended for 2 story work with jacks and plank, I'm not a big fan of heights anyways-compound that fear with the wiggle wobble that trasmits through the plank when it's set up and Im like a cat in a tree LOL!!! I also like the fact with these 28'ers they've come in handy on shorter houses, we can break them aprat and escentally make 2 ladders out of 1. When roofing single stories I'll break them both apart install all our jacks and planks and run the entire length of the building.
None of my other fiberglass ladders have ever had the privledge of shelter when not in use, they all sit outdoors. I've got 6 fiberglass step ladders all 10yrs old, paint still bright and legs are solid as ever. I've borrowed a fiberglass ext a few times. Love the stability, but as noted if I had to deal with them everyday I'd start using steroids and look like Arnold!!:)
With my step ladders I like the Werner better. We've had 2 Kellers and the aluminum corner bracing was always the weakest link and tend to bend/buckle in less than ideal conditions and need replaced after a few years. The Werner uses the huge plastic corner bracing and so far not a peep outta them :Thumbs:
Heavy fiberglass ladders
I worked for the cable company once and did ladder training, I always impress the girls with how easy i can unload manage and place a 28' 32' fib ladder. tilt and Grab from back or rope side of ladder, stand and unload at the center of ladders gravity and military press up off truck. put feet on grnd. tilt to 180 vert. 'from back side' (rope side) and grab with one arm outstretched low near 3rd rung and your other arm above your head (about 7th rung). Use lower arm strength to lift ladder and upper arm to control. Walk with it like your carrying the biggest flag in the parade. Put feet down 4-5' from wall with 'you between ladder' and wall, building (or pole), tilt to 180 vert. pick up and drop 4" to set, adj feet. pull rope up and push up steps,while you are 'between', behind, ladder this is the key, and tilt to building while you are under. Tilt back and adjust the same way you carried ladder. i am 6ft. but I watched 145 pound guys carry and set up these with ease using the under and behind method.
Look at the feet they adjust for unbalanced land you need that, weak guys need a lite ladder to work fast buy heavy for theforty footer but a 30 or 26 go lite and invest in a ladder leveler they are awesome in rocky spots
We've got aluminum extension ladders (IA or IAA) up to 40', but our the workhorses are the 24-footers. Around here, they'll handle 95% of the residential work; sometimes we've gone a year or more without breaking out the 32- or 40-footers, which doesn't hurt my feelings. The 24s are also handy since they'll overlap with 8-foot steps. When we're working off ladders, jacks, and planks, we'll work down until we have the ladders telescoped all of the way and the jacks at the top. The next set is the planks between 8-foot stepladders and we've got the wall covered. No having to go back and touch up "ladder prints" and no having to reach through a ladder to paint.
I'll also second the call for levelers. Here in the hilly Palouse, they are lifesavers, or at least profit-savers.
1 - 20 of 30 Posts
