1 - 15 of 15 Posts
Have a combination of greenboard/regular board.
Looking for the best sealer (within reason) to keep moisture from entering.
Discussion Starter #10
If you're talking about inside the tub/shower area, you need two coats of liquid waterproofing. Redguard, Aquadefense or similar....or Kerdi membrane. (This is for tile?)
No tile. Only want to prime/seal on raw drywall, not after the paint (higher gloss paint).
If you're looking for the best drywall sealer/primer I'd recommend Gardz. Apply 2 coats to ensure you didn't miss anything, but 1 coat should work fine if you apply it as heavy as you can. Because Gardz is so thin (think water like consistency) it penetrates into the drywall and seals better than anything else I've found.
Here's a link to the product data sheet: http://www.rustoleum.com/~/media/Di...GDZ-01_GARDZ_High_Performance_Sealer_TDS.ashx
If that's not available then I'd use 1-2-3.
1 - 15 of 15 Posts
