21 - 40 of 60 Posts
You must be misunderstanding me, we have bent joists, railing, fascia and so on, people were wanting radius decks as long as we gave it away. we did 2 to get the pics, even installed radius edge w/bent deck boards to match the radius in the show room on a 900 sq. ft. trex origins deck, put a pond in front of it, had bushes, so on. Set the whole thing up real nice.
Once we started to charge for it, the interest went away.
Which is what I was saying.
Do people really pay money for this stuff, or are you guys giving it away?
Im the same way ill bid a little lower to get that job with killer pics.
Its like some one said on this site. If you want maple crown moulding done to perfection and cheap... its just not happening sister.
Discussion starter · #31 ·
Mike, I am curious why you had to make a template out of 1/4" material to run the router bit against instead of simply running a 2" flush-cutting bit with a bearing on end against the curved rim joist already present? Would it be too much to ask of a double bladed bit and rather more of a job for a spiral bit?
not enough for me to do, when there is so much other better work, and you can go bolt your railing to all the kerf cut bonds you want.
you'll pay for it in the long run.
Can't you reinforce the kerf cuts with some epoxy before installing the posts?
If you'll look closely that rim is far from an acceptable guide. It's very uneven, and not round. The picture I posted at the start of this thread with the kerfs is another deck. I did run the router along the rim on that one. With a bottom bearing. With that said in hindsight I would've made a 3/8" template on top. Simply because the radius came out so much cleaner and smoother. :thumbsup:
The template and router was a good idea! ;)
I do have to say 1911 you were the guy that walked me through that radius deck and gave me the idea of the top template. Your Gracious teachings have not been forgotten sir. :thumbsup:
And I have you to thank for blessing me with the avocado fetish. :laughing:
I might add I had 2 avocados and a bag of chips just a few minutes ago.
Unbelievable you mentioned that. I just came back from the store and made the MLW special avocado dip! I mean I just ate about 2 full advos. I had another hankering!
21 - 40 of 60 Posts
