If you are talking about prepping subfloors prior to install, I use an edger. A 7" grinder with a 36 grit sanding disc works pretty good too, but kicks out a helluva lot of dust....not that cool in occupied but fine for new construction.
I hope you didn't install hardwood flooring on top of that particle board in the pic.For prepping subfloor especially that which has a bunch of old 1/4" staples in it I have found that the best tool is a Hilti DCG500 and Dustless cup shroud attachment. It cuts down everything high and leaves the surface like it was sanded with 60 grit... the wear on the wheel is unique as it pulls more bonding material leaving more exposed diamond... not as bad as mortar residue (wears the cup fastest) but more than when running on concrete.
You can see that this pic was taken after being used on wood from the yellow orange color of the diamond blocks
Craig
