Here is the post I referred to. It was written by Jim Parodi of NY and posted on the American Paperhanging Network.
I just finished reading the Consumer Reports roundup of interior paints.
As usual it is written from the DIY perspective and offers little for
the professional. And as usual, I reject most of the criteria used to
judge these paints:
Major problem #1--- Once again CU only chooses the national brands. I
understand why, since it does the DIYer little good to get stoked about
a paint if they can't get it in their state. But the omission of great
regional brands is a fatal error and renders this seemingly
"comprehensive" roundup a complete failure. Maybe when they include
Coronado, Porter, Muralo, Touraine, and so many others it will be worth
a revisit.
Problem #2--- Would it be too obvious to point out that the most
important aspect in our superficial trade is "HOW DOES IT LOOK?" CU
spends a millisecond on this subject and cubbyholes this into "Does it
appear flatter than advertised or glossier than advertised." "Does it
go on smoothly" This is important to the DIYer because they are always
newbies. Pros are familiar with sheen levels after one or two jobs and
aren't surprised by sheen. "Brush glide" (smooth application) is nice,
but even if a paint is less user friendly, pros will usually find a way
around it---or ignore it completely if they think the finished product
is worth the extra effort.
Problem # 3- Hiding and Mildew Resistance are nice. But once again if
a paint gives a better appearance with two coats pros will use it.
(DIYers want a one coat so they can get back to football on TV.) And
scrubbability? CU does not even get into the newer "flat enamels" or
ceramics. Muralo Ultra Ceramic, Pratt &Lambert Accolade, Coronado Cerama
Gard are regional and therefore not mentioned.
Problem # 4-- Do the words "leveling", "flashing", "blocking", "edge
cling", "sagging", "enamel holdout", "recoat time", "cure time", mean
anything to you? Of course they do-you're a pro. They mean nothing to
a DIYer so CU completely ignores these ESSENTIAL paint qualities in
their review.
Problem # 5--- Such a bunch of paint yokels I haven't seen in recent
memory...Did anybody see the word PRIMER mentioned at all? Yes CU,
paint companies have these things that go on first and these things are
part of the "system" than can make or break a job. So with primers you
can tackle painting garbage painted atrium halls with uniform finish and
get good PROFESSIONAL results over patching compounds.
This review is a joke for the pro. Take it and send it to your DIY
relative.
Quote
That all makes sense to me.
