Picked this up to try it out mainly for it's ability to "age" wood. Basically run the tool over a piece of wood, and it gives it a light driftwood looking effect. In this case I used roasted red oak. Here is the tool, I know, China, but the Makita version is around $600 and I'll never justify that for as little as I'll use it... Bauer Surface Conditioning Tool
Then I had to purchase this from Amazon. You can get different grits, I started out with 60, and honestly don't see much need to use the 80 because this worked well... Amazon Nylon Sanding Drum
In short, I'm very happy with the tool, did what I needed to well. I started out pushing too hard and got a little burning, then figured out that if I don't push at all and just let the tool eat it did a fantastic job with no burning. This was on a rough planed piece of wood, I won't do that agin, I'll finish plane the piece before doing this when I actually ise it on a project. Although I am curious what it'll do to a rough sawn piece as well, I'll try that next.
This tool is also good for knocking rust and scale off steel, for example if you were going to paint a rusty, steel frame you could do this rather than sand blasting if you didn't have a sand blaster.
Again, pretty versatile tool, I don't regret picking it up. I'll post pics of the tool, then post again with the board I did.
This is what it comes with, minus the nylon wheels I got thru Amazon (gray with yellow centers). Kinda nice that it includes the allen wrenches, as well as spare brushes that I'll more than likely lose...
