Looking for the best way to finish a basement window. I guess it would matter if its a glass panel window or a glass block window but I'll leave it open for now. I'm talking about framing a 2x4 wall inside the foundation wall and finishing that with drywall. That leaves a small gap between the framing and the foundation wall, then you have a couple more inches until you get to the window itself.
In the past I've used 1x material to box around the window, kind of an oversized extension jamb, then caulked where the wood meets the concrete block/mortar/glass (take your pick). I've also drywalled up to the same locations and finished the back edge with caulk.
Suggestions? Thanks.
