bein's? That funny
yup you're right Tom - most people do have the downspouts empty into a little splash block and that's it. Gutters clogged up too. These are obviously things that the homeowner can address themselves - or hire a handyman to do. We actually sent out a neat booklet that discussed things like that, and gave the homeowner tips on the "do-it-yourself" type repairs.
But it's still not a solution to the problem. It doesn't address three other problems...
- Water from capilary veings of water underground
- Rising water table/ground water
- False Water Table
You guys probably know a good about these types of things... but here's a good tool that shows how water gets in a basement -
http://basementsystems.com/learning_center/basement/clay_bowl_effect.php
concretemasonry - notes on your post...
Just admit it - the most effective and economical way of eliminating basement leakage is to control both the roof runoff and the surface drainage.
economical - yes as long as it that's the only problem and it doesn't fail. Replacing drywall and carpeting and other finishing can be quite costly when it's damaged by water. Effective? Hardly.
After that, you look at the more costly methods. They range from the licensed/franchised "band-aids" with questionable results to the time-proven and recommended methods to eliminate the water at or below the footing level, which also reduces the hydrostatic pressure behind the wall and under the slab. Floor level drainage collectors that collect water that has already invaded the living space are not a solution.
Agreed. Maybe we're making the same point here. The gutters and downspouts should certianly be looked at and done properly... but that's only fixing one part of the issue.
Then again, you did say the best way is through roof runoff and surface drainage, which contradicts this statement. Maybe we're not making the same point.
I don't know how much experience you had in the non-existant Virginia Beach basement market, but in my 5 years of dealing with concrete and masonry construction there, I saw fewer basements than I saw elsewhere in a week. That would be the least I ever saw in one week in 30 years of experience in the basement business.
Yup - not a whole lot of basements here - the company mostly did foundation repair work (settlement issues). However... they worked through the entire mid-atlantic region. Did a bit of driving with that company (I lived near DC at the time)
You have to address the problems first, offer ALL solutions and then sell a "bandaid" system if the customer rejects the time-proven methods. Anyone that puts their propietary name on generic products/methods is open to any and all critcism.
Sell a Band-Aid System? That's just plain silly. Why would you even offer it? How would you offer any assurance to them that it would work?
What's the last line about?
