Basement Columns
101K views 27 replies 17 participants last post by  blackte
Hi, Guys easy Question for you. I'm just finishing up on a basement job and was wondering if there is an easy way to box out the columns.
I was thinking of making a two piece base and top to fit around the column and attach some 6" trim to box it out. I just started doing this type of work so any input would be great!!
Any thoughts??
Rambone
Master Deck Builder
#2 · (Edited)
I have done that in the past and it works fine. There are also prefab post wraps on the market that you might want to look at.
I have also added a support around the center point of the post in the past because it was for a playroom and was probably going to take a lot of abuse (HO's request, although I did not see a need for it.) If it is a simple wrap I usually chase it around the lolly and chamfer the edges.
#5 ·
Basement Column Wrap Recipe:
1) Use 1x6 material to build a three-sided, "u-shaped" box to slide around column. Keep the height of this box about 3/8" in short of the floor to ceiling height. You can either chase the butts or miter the edges. Unless you have a very good TS, I do not recomend mitering because it's hard to make an 8' long perfect bevel on a small TS.
2) Slide the three-sided box around column. Attach fourth side.
3) The wrap is now loose around the column, but obviously cannot come off.
4) Shim the bottom (or top) of the wrap to make plumb and square. Shim it tight so it won't move.
5) drill 8 3/8" holes in the wrap. One on each side of the wrap 2" down from top and 2" up from bottom.
6) Use NON-expanding foam and stick the hose into each hole and shoot.
7)Trim top with crown and bottom with base.
You are done.
You can make all sorts of cool varations with rails and stiles, panel molding, etc.
Kind of like "Pimp your Column"
#9 ·
You're right, it's damn hard to make a perfectly staight bevel on a job site TS. I always use my 8' stabila and clamp it to the sheet and use a good shape circ with a sharp new blade, never had a bad one yet.
Another good tip, if you paint it, is to use MDO, you'll have no grain rise to sand down between coats that way. It'll even take the abuse of the out of doors.
Wack
#6 ·
There is also a company on line that makes rounded column covers...
We installed a few sets in one basment job to give a 'higher-end' touch to it. The home owner really liked the look over a basic 'box' type covering...
Look up "The Architectural Depot (DOT) com"
Under Lally or Lolly column cover..
They make cherry, paintgrade and other staingrade covers...
-My 2 cents
#7 ·
Make the box and put a couple of squirts of expanding foam in it. This will solidify the box around the post and glue the box to the post. Don't over do it or it may blow the box apart. It needs to be the foam that dries hard (ie: Great Stuff) not the latex stuff for windows and doors.
#12 ·
Geez...didn't I just say that in the post above yours in step 6?
I have used the round columns from architectural depot and they are OK, but the rounded trim caps they give you are a ***** to mate properly and require A LOT of sanding.
HB&G just released a new type of column wrap I saw at a show a couple of weeks ago. It's made of PVC and can be used inside and outside. Looks like the way to go from now on. It uses lock miters.
#21 ·
If it makes since in the floor plan, it a half-wall can be used between two posts (here to delineate a walkway and keep traffic out of the way) and still leave open sight lines. Actually in this case only one column was needed, but I added two for effect.
I also like to make mitered, tapered columns. Instead of using a table saw, I used a rail saw (Makita saw on a EZ guide rail) to make the tapered column faces.
#28 ·
Three sided "U" shape box, short of ceiling height. Set the bottom in construction adhesive to keep it from moving around. I always when framing add extra blocking around the post at the ceiling to have something to shoot the crown and box to. Once the three sides are set ad the four side. Once your box is complete, you can continue to add as much trim around the top, middle, and bottom as you would like. The attached pic are pretty simple, but what the client wanted. One of those is a sewer stack, and has a clean-out lid attached.
