Could you use pocket screws? Is the outside of the cabinet visible??
Good idea but how the heck would you do that without melting it all to $h1thmmm (brainstorm) I wonder if Azek is hot air weldable
Tom, where did you see plastic biscuits? That may be the answer :thumbsup:
I agree with the pocket screws. Not so much on the plywood. I would be afraid of moisture and rot or swelling between the materials....make your own plastic biscuits w/ the table saw...
I wouldn't trust pocket screws to hold this together-too much abuse especially for a free standing unit. How about instead making a wood/plywood carcass inside for strength and then skin it w/ 3/8" on the sides and regular 3/4" for the front (talking Azek here). Not sure if it's ok to bond pywood and Azek-wonder if 'foamboard' adhesive works? I'm using PL200 for my sheetgoods to adhere it to the backing material-can't speak yet of it's durability in terms of the bond.
You will not be sorry, I've tried others and this is the ticket in my opinion. Look back at my first post. All connections were made with Christy's and these pics were taken at least 2 years after completion of the jobs.:thumbsup:I'm going to look for that Christie's Red Hot also
Azek sheet goods are available in 3/8, 1/2, 3/4 and 5/4 thickness. I have gotten them up to 4x10 sheets very readily.I didn't know Azex came in 3/8" I thought only 3/4" and 1/2".
So do you use the clear PVC solvent glue or the stuff in the tube they sell for fences?You will not be sorry, I've tried others and this is the ticket in my opinion. Look back at my first post. All connections were made with Christy's and these pics were taken at least 2 years after completion of the jobs.:thumbsup:
Why not build the box out of 3/4 or 5/4 sheet goods, then use adhesive to mount the faceframe?:thumbsup:I thought about biscuits, but don't think they will work wood to PVC
That's my plan. Use a 3/4 sheet ripped to the dimensions I need. I was only aware of Oatey PVC cement. I know I can separate pipe welded with that stuff so I know it isn't super strong and wasn't sure it would hold.Why not build the box out of 3/4 or 5/4 sheet goods, then use adhesive to mount the faceframe?:thumbsup:
This is what I prefer to work with. One tube will go a long way. I did every connection on my house (the siding chronicles thread) with a little over one tube. That door is two sheets of 3/4 with the 3/4 overlay frame. I used a few 18 guage SS brads to tack everything in place until the adhesive set along with some clamps with blocking to spread out the pressure. It is 100% Azek, fairly heavy and I used 2" screws on the hinges. As I said this pic is at least 2 years after the completion of the project.:thumbsup:So do you use the clear PVC solvent glue or the stuff in the tube they sell for fences?
I am actually going to make the door similar to the one you pictured. Nice stuff BTW.
So that door was solvent welded only? No other fasteners?
