If you can tape and coat 2 standard 12-1400 sq ft houses a day with 2 guys and your knifes then finish up both the next morning with the texture, by all means keep doing what your doing, otherwise if you want to step up and turn some profits and are specializing in the drywall biz, you HAVE to be up on the latest time savers, otherwise your stuck in the "ole boy" stubborn mentaility that is hurting nobody else but yourself and your bank account. Can you imagine excavators diggin basements with shovels....yeah, it's that big of a deal using the old knife and tape compared to 20th century advances.boardslinger said:Man you guys are all WAY to technical for me, I only use my 6", 8", 10", and 12" knife.
As far as brands go, they are all copies of Ames, so they are very similar if not identical. Ames also owns half of the other manufacturers, starting with TapeTech. Ames rental is a minimum of 16 days and monthly, the rates are high enough that you can own a set with 6 months rental. With a little video instruction, the tube is mastered in a few weeks. There are videos on YouTube of taping tools in action.You're looking at several thousand dollars for any automatic taping tool set while Ames rents the whole set for dollars a day and they maintain the things for you. It takes years to master a Tube so one might want to rent until they get the hang of it......
What brand of Automatic Taping and Finishing Tools do you find most widely used by your drywallers?
I think a compound tube with some appliacator heads may be for u.i'm on the fence... if there is a decent learning curve, it might not be best for me, i do maybe 100 boards a year with the work i do... typically bath guts and basements.
i would love to save time finishing, but i dont think i do enough to really learn the tools.
maybe i should just get the boxes and stick to using the knife in the corners......
I think the opposite... most time is spent in the corners so I want tools to go faster. I'm like you as to the amount of rock I finish and that's the problem, if you don't do it every day, I spend a day getting back up to speed again. Corner tools to me are the best money spent.... and tapers.i'm on the fence... if there is a decent learning curve, it might not be best for me, i do maybe 100 boards a year with the work i do... typically bath guts and basements.
NO!!maybe i should just get the boxes and stick to using the knife in the corners......
whats that?I think a compound tube with some appliacator heads may be for u.
you make a great point:thumbsup:I think the opposite... most time is spent in the corners so I want tools to go faster. I'm like you as to the amount of rock I finish and that's the problem, if you don't do it every day, I spend a day getting back up to speed again. Corner tools to me are the best money spent.... and tapers.
My two pennies.
lol... so you suggest just the roller and flusher? knife on the mut and tape first or would i have to use a banjo? i made a big mess the one time i tried to use a banjo i bought from depot:whistlingNO!!
If you are doing only small jobs but want to step it up if nothing else get the corner tools! Yes the boxes will have you finishing faster but the corners is where you will save the most amount of time if you get the "big boy tools". At least a roller and a flusher!
Act now, don't walk run and buy these tools now before it is too late!:laughing:
