1 - 18 of 18 Posts
I'd say it's better than using it over previously painted walls... It's thick and needs to be re-rolled after a careful initial roll to get a non-obnoxious stipple. At least that's my experience with the stuff. Excellent coverage though.
I haven't had the opportunity to try Aura yet but looking forward to giving it a whirl. My BM rep told me the same thing - 1 coat primer and 1 coat Aura and the job is done (on new drywall). I'm not certain that he meant using Aura as the primer, however, and I find it hard to imagine priming raw drywall with a thick paint such as this. I wouldn't be surprised if Aura has an actual primer product (i.e. a thinned down version for prime coating). I shall have to investigate further.
vandy
Because of the high cost, prime walls with a cheap primer tinted to match the finish color, then topcoat with Aura.
Or you can use 2 coats of Aura over raw drywall. It seems like I use 2 coats of mid grade finish paint (SW 200 line) over raw drywall all of the time anymore.
We did a large new office building with 9 foot walls only using 2 coats of Aura over the new drywall. This is what the GC and customer wanted and spec'd the job for. Looked good. We even used Aura to topcoat the 9 food hollow metal doorframes. Also looked good.
House Painters Reading PA
We have actually applied 2 coats of BM Aqua Pearl on new sheet rock and it worked out well. We would have the rock wet moped after it was sanded and turned out awesome. I would have preferred a undercoater enamel primer, but thats what the builder had it specs at.
Particulate Filter
Discussion Starter · #11 ·
I'm not familiar with wet mopping. I assume that just means you took a sponge and lightly wiped off all the dust and let it dry before painting? Are you saying you did do it and it made a difference?
I'm not an expert user of sponges, although I've seen the difference in sponge sanding makes on a massive residential job I worked several years ago. IT was the most professional drywall job I've ever seen. They left the house dust-free, even in the holes, with no scratched paper and minimal touch-ups.
On the basement job, which was approx 20x25 I used a wet cloth to get the walls tip-top before applying 2 coats of Aura. The color match between new and old wall were excellent using only two coats of a deep base over the mud and drywall. Phenomenal. Really
vandy
What did you prep the hollow door frames with?[/quote]
primed with pigmented shellac if I remember correctly, topcoated with Aura.
When we worked on new construction we had the luck to go behind the best drywall company I have ever worked with. They guys were ******* and out there. They lived on the edge, were loud, but so much fun. If we filmed it we could have been the number one reality construction show really.
Anyhow, wet mopping does make the difference. Even paint new construction, but you could see the grooves the sandpaper made(Burned up the rock)? Well, wet mopping cures all that and keeps everything dust free. We were the only company I knew that dusted all their walls prior to painting and the touch up was so much better. With wet mopping we did not have to dust a thing. They had these huge microfiber mops and were quick. We actually could breathe after we walked onto the project.
...jammin
From another forum:
slickshift said:
With Aura on new drywall, as with most "self-primers", the finish will still come out better if primed first
(not so on plaster...just go right to it in those cases)
However, Aura does have other advantages
Like ultra-low VOCs, burnish-resistance, wash-ability, durability, color-retention, and downright beautiful display of rich and/or complex colors
You might "get-away with" one coat over tinted primer, but the other attributes could suffer
1 - 18 of 18 Posts
