Pics would help...can you build out the wall behind the toilet?
Give her one of these....:clap:
Ya, something's wrong here.... It's a standard 12" rough-in Kohler Memoirs. Problem is, the flange is 14-1/2" from the back wall, house built in the 40's. I set the toilet over the flange and then balanced the tank on it just to check and was looking at about a 6-8" gap between the back of the tank and the wall...
My thought exactly! Unfortunately, I'm not back there til Thurs. to investigate this a bit more. It just doesn't make sense.A 12" rough-in toilet on a 12" roughed-in flange sits just 1/4" to 1/2" off the wall. Move that flange out 2 1/2" to 14 1/2" and the tank should be 2 1/2" from the wall, not 6" to 8". Even a 10" rough-in toilet on a 14 1/2" roughed-in flange would only be 4 1/2 " off the wall.
Something's not right.
In checking further, the Memoirs line doesn't have a 10" rough-in anyway, so that can't be the issue. Also, in case anyone's wondering whether I'm a bigger dumbass than I appear to be, I did check to make sure I correctly placed the base over the flange when dry-fitting. :laughing:
When you dry fitted this are you sure the tank bolt holes were not over the seat bolt holes. That would allow for the big dimension you are showing ??? ROTFLMAO
She will need more than 1 for the "french flush"Give her one of these....:clap:
Why tear up the flange when you can just buy a 14'' rough toilet to fix the problem?When you rough for a 14" toilet you add an extra 1/2 for sheet rock so you end up with about an inch behind the tank.In order to install that flange you would have to tear up a few tile and depending on the piping you may not have enough room.Cheaper to buy the toilet.:w00t:
Ya gotta admit...that is a damn fine shot of an offset flange.
