1 - 4 of 4 Posts
Look on the upper section of the back of the can. It will tell you.
(Never works out that way).
Standard interior latex has a coverage area of 300-400 sqft per gallon. On smooth walls and ceilings I can usually sqeeze out 300.
And it always depends on how thick of a roller your are using. Dont forget about 2nd coats either.
When the rear of the can says "300-400 sqft" per gallon, dont plan on the 400.
Manufacturers figure on a white wall and who knows what application method. I'd like to see them start with Barbie Pink, definitely not covered in one coat.
On small jobs, I usually figure about 20% less than the minimum, on larger jobs, 10%. Sprayed primer, seal it or write off the first coat at least. Cheap, white paint will throw a gray cast to your first coat if you decide to go gloss.
1 - 4 of 4 Posts
