Had a inspector tell me your not allowed to cut birdsmouths anymore in rafters. All I can see in IRC is 1/4 depth notch , 1/6 length depth?
Shiz- ill admit to over cutting my stair stringers. Almost all the stairs I build are 4' or under on width and in a place where the sides are nailed to a wall. Only the 2 midspan stringers are fully bearing. I don't how the 1"1/4 lsl AND the 3/4 osb I use for riser material AND the 1"1/8 stair tread I put on are in any way inferior just because I over bit the stringer. I could spend the extra time to hand saw but why waste time on something that makes no difference and that no one will see.Rob1954 said:Cut your stair stringers that way also? Most carpenters I know would consider that kind of work substandard. But then I don't spend much time in an environment where production trumps craftsmanship.
Do you always run a key/ king common and then cut the hips short like in your pic, or just when usin double hips?loneframer said:Figured I'd throw out a few bones and show a few pics of my production built, lack of pride and craftsmanship hackery.:sad:
I'd do the same on something seen. Just goes to show you can't make blanket statements like "over cutting is bein a hack". We all encounter different situations where different methods are used.loneframer said:I don't overcut mine because 95% or better are exterior stairs built from pressure treated lumber and are almost always visible from the underside. Other than appearance and trying to avoid a moisture/dirt trap, I see no harm in overcutting stairs either.
If you look closely at the first and second pics I posted, there is a steel plate sandwiched between LVL ridges. If I recall, it's around 38' long and has a pitch on either end of it. Scary getting that set and pinned in place, especially since one end bears on a CMU wall that didn't exist when the beam was set.:laughing:Ive been running my hips the the ridge and then cutting the key short. There's not much of a way to nail the ridge to key till you get the hips up. Just the way I've been doin it, maybe I'll try yur way next time![]()
I agree totally! It's not a stair stringer. They only possible problem you could have by over cutting a birds mouth is making the overhang weaker. But you would have to really overcut. All it does is set up your overhang and give you a "stop" so your rafters are all set in the same distance from the ridge and you can maintain a consistent overhang. Any framer has built parts of a roof where there is no birds mouth. They all get hurricane ties anyway.loneframer said:I've hand cut hundreds of roofs and have NEVER finished a birdsmouth cut with a handsaw. I've also done the exact same thing with the seat cuts to match bastard roof HAPs. Never had an issue with an inspector and in 30+ years, have never seen a structural issue as a result of doing so.
