1 - 20 of 20 Posts
· GC
Was wondering how many companies are using a Graco sprayer to skim coat walls instead of applying by hand. They are about 5k to buy but from what I have seen save alot of time and labor. They have a new 240 volt one that looks as if you could spray smooth stucco through it.
· EMF, PLC specialist
You can spray elastic foundation covering as well as everything else, really nice gadget. A contractor, gas probably a better choice since you don't want to use electricity from your customer.
Are you spraying the mud on after you have run your box on flats, butts, beads, screws and sanded? So you tape, fill with a seven inch, skim with a ten inch and skim again with a twelve inch, then sand and spray the mud? Or some other way?
· GC
Dont buy one less you have enough work to support it...
Renting is the best way until you have enough jobs to pay for the equipment over time.
I have checked the rental yards and they do not have a sprayer large enough to spray a level 5 finish. I have 2 new houses coming in the works and the price to skim them is what I would pay for the sprayer. I have alot of tools sitting but they are garaged and I am planning on building for at least 10 more years. I have subbed out to drywall crews that spray skim and ones that do it by hand. The sprayer is alot more efficient. I have searched for a used one but no luck.
I tape with a bazooka, bed with an 8, skim with a 10. Then sand, then spray the level 5, then sand again. Butts ae run twice with a 10 and hand run with a 12 (on average, butts are kinda indavidual) corners are taped and glazed with a 3" and run again with a 3 1/2 *sometimes, if conditions are bad I'll run em a third time with a 2.
You have to come to a level 4, then sand, then spray level 5 then sand again.
· GC
Discussion Starter · #15 ·
The demo I went to by graco had em putting a gallon of water to a ready mud bucket. stir with a paint augur and away you go.
Same way I have seen. 1 guy with a helper mixing and delivering was able 2 spray both houses (2450 sq ft + 2 car garage each) in 1 day. Each house required 3-4 hours to sand to perfect finish (1 guy 1 day). I paid $2200 extra per house for skim coat over level 4.
GRACO MARK lV SPRAYER W/HOPPER AND NORTHSTAR COMPRESSOR
Item condition:Used
Time left:1 day 21 hours (Aug 04, 200918:39:24 PDT)[Refresh]
Bid history:0 bids
Starting bid:US $1,975.00
Your max bid:US $Place bidPlace bid
(Enter US $1,975.00 or more)
Now watching in My eBay (10 items)
Shipping:Local pick-up offered.See more services See discounts | See all detailsSee shipping below
Returns:No Returns Accepted
Coverage:pay with
and your full purchase price is covered | See terms
· GC
Discussion Starter · #20 ·
Brocktologist or Capt-Sheetrock,
Lets say you have a house with 20,000' of drywall.
How many man hours to mask off, spray, then sand, ceilings and walls?
How much material is used?
The 2 houses I had done were 220 4x12 sheets each which breaks down to around 20,000 after scrap. 1 prep guy and 1 spray guy taped masked and sprayed both houses in one day. The taper came back and sanded both in one day. They used around 25 5 gallon buckets for both.
1 - 20 of 20 Posts
