1 - 10 of 10 Posts
Im working on a medium size ranch(3800 sq ft)..it has over 850,000 btu's.....they really like gas appliances
boiler,2 furnaces, modine, 3 cooktops, 2 fire places, dryer
house is 125' long
I was shocked to see it wouldn't come close to working w/ 1 1/2" gas pipe....ive run 2" in commercial, but never in a house before
the thing I never get is the meter....its rated for 625cfm and has a 1 1/4" outlet........ive run into this before and everytime I call the gas company they say the smaller meter will work even though the BTU's don't match up with the meter CFM
any idea why?
Probably has to do with the fact that there is no flow loss due to distance at the meter, where your numbers are including the piping loss.
I commonly see 2 inch in large homes here on the island, especially with all the nat gas generators going in now.
Huggy....
I've wondered the very same thing.... It seems the meter outlet would act as a choke at 3/4 or 1" and would be the major and material flow restriction....
And then we are then paying for 1.5 or 2 pipe to minimize any further flow restriction, because the meter is already created alot of restriction.
(Did that make sense)?
· Thom
I once did a residence with 2" pipe and a 5# pressure system. We installed regulators where the branches split from the main.
You can get a lot more gas through the meter if the regulator is installed after the meter. Then, the amount of gas available is a function of pressure.
Yes... But that is not what Huggy is talking about.
I saw a man walking his dog in Detroit.:rolleyes:
Discussion Starter · #10 ·
I cant change the meter to a 2lb system because its already there and installed....I have to work with whats there.....
my pipe machine only threads up to 1 1/2", so I had to take measurements and drive to the supply house to thread it...luckily I only need á short run of 2"and I had enough left over from another job years ago....so the pipe was free
1 - 10 of 10 Posts
