1 - 8 of 8 Posts
called certainteed and they said NOT to power,could take the finish off.use a hose.
I was referring to vinyl siding. If if you meant pre-finished fiber cement siding, then yes, stick to a hose.
But, as with any pressure washer it depends on the PSI of the unit. If someone is using a 3000psi unit and is not aware of it's power, and holds the nozzle too close, you can put a hole clean through solid wood siding for that matter - and obviously can damage vinyl siding or any other type of siding. Proper use of a pressure washer (especially the very high powered ones) requires a little common sense, instruction, and experimentation. ;)
Some of the vinyl siding (I know Certainteed for sure has some) has a painted on finish.
I have powerwashed some painted steel siding on my own home and it holds up fine (Edco). I definitely wouldn't get carried away with the high PSI units.
I believe it's "monster" sells some powerwash soap specifically for siding and is safe to use (environmentally). Got it from northern tool.
MJW is right. You can use the 3000 unit, just use a 20 degree fan blade. Start at the top work down away from laps. Spray lazy helper guy at close range with the 0 blade for making you power wash in the snow.
i remember my first powerwash,it was an old white aluminum siding joband tha more i washed it the grayer it got:blink:then i realized it was the the old paint on it was mostly chalk and the gray part was actually the metal underneath:shutup:....new siding job:clap:
1 - 8 of 8 Posts
