T300.5 hasn't changed since at least 1999 [the last year I have an NEC on computer for].
Why are you looking for IRC codes?
If rated 120volts or less and GFCI protected, 12"
otherwise 24"
That says "2007 California Electrical Code" on the bottom.If this ( link ) is the correct code...
Isn't there a 20A requirement also? :whistling
I'd like to get an inspection sticker on some work I did on my own home back then. Getting called to Iraq in '03 kind of distracted me from getting the inspections done at the time. I never got around to it after I got back, but since work is slow right now, I have time to clean up loose ends.Celtic said:...
I'm curious as to what the investigation is all about
Tell me about it [check a recent thread i started :laughing:]But when the answer is free you don't get all the info.:thumbsup:
