Personally I prefer White-Rodgers line of thermostats if I am not using a specialty stat such as the Infinity or Thermidistat. I used to use Honeywell all the time and then started having issues with many of their products and the T8700 series ate my lunch in warranty changeout. Here is a link to their product line for heat pumps with their Programmable, non-programmable and mechanical line all together for comparison. There are many many choices out there but one line to steer away from are Lux/Hunter stats. Many professionals will tell you (and it will be the truth) they are cheap cheap cheap line that will make your Honeywell's look like angels. Good luck!
http://www.white-rodgers.com/homeowner/ptech/thermo/thermo_04.htm
