Status
Not open for further replies.
1 - 3 of 3 Posts
I need to put frp over some painted walls not the problem but the customer has 2 small walls with some old wallpaper on them which can't be removed so my question is can I go over the wallpaper with frp even though the adhevsive says not for application over wallpaper???? Has anyone done this and if so what can happen???
pro
The adhesive is just like any other glue and can be tempermental. The walls need to be clean and free from oils dirt ect. There is a good chance that the moisture from the adhesive will loosen the wall paper and over time the panel could come off. Wich leads me to the next point if that does happen it leaves you nothing to stand on with the home owner or the manufactuer. Even in the case were there was a defect in product. Try and take off the paper.
Good answer, Huck.
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
1 - 3 of 3 Posts
Status
