Please write if u know the answer 100%. . . .
1)What conduit you must use for exterior wiring
a.Ridgid
b.EMT
c.PVC
d.FMT
Are you sure you're not missing part of the question??
2)How much percentage you must remove water from construction side during water storm
a.100
b.75
c.80
d.65
Can't remember right off, maybe 65??
3)In Raceway u have 5 conductors what percentage you must use for ampacity of wires ?
a.50 b.60 c.70 d.80
Table 310.15(b)2a states you must use 80%
4)U have supply 480V.Your building need 120/208v 400a service.what size transformer u must use ?
a.150KVA b.200KVA c.500Kva .d.600kva
480V x 400a= 192000VA = 192kva so use 200kva
a.Ridgid
b.EMT
c.PVC
d.FMT
a.100
b.75
c.80
d.65
a.50 b.60 c.70 d.80
I would answer, but, I think I am only 99% sure.....
and its
ANSWER THESE QUESTIONS:whistling
..........Batik, you need to acclimate to our culture a little.
.............480V*AMPinput=208V*AMPoutput => KVA=400A*208=83KVA
CAN U EXPLAIN ME WHERE AM I WRONG ?
how can a math equation have three equal signs?
Beside the fact that it makes absolutely no sense.
8/16 = 4/8 = 2/4 = 1/2 = .5
a.Ridgid
b.EMT
c.PVC
d.FMT
a.100
b.75
c.80
d.65
a.50 b.60 c.70 d.80
408 SPARKY i See you are far from away from math this sign => it is not a equal this = sign ....Thios sign => it is math sigh which mens "Means"...i will explain you
18x=36 =>x=36/18=2 ............. ?
