I need some suggestions on how to soffit a cantilever area. The 70's home has T1-11 which hangs over past the existing 3/8" plywood soffit nailed to the bottom of the joists on the exterior. I would like to add a aluminum soffit which is flush with the bottom of the T1-11 (1 1/2" below the existing plywood soffit). But I dont want to nail the soffit to the edge of the old T1-11. And the only reason I need to do this is to hide the nails which will penetrate the T1-11 when I nail the starter strip on which would be seen walking out of the garage.
What would be the correct way?
Nail your alum F channel to the home, and add a nailer on the inside of the overhanging T1-11 flush with the bottom? Not sure if like this method because I could not hide the soffit nails without making a trim piece with 1 1/2" leg instead of the normal 5/8" since I need to hit the nailer "behind" the T1-11 siding.
Or how else could I hide the nails without soffiting this area?
