they make one that is bent for use with the preloaded hangers
http://www.leaf-relief.com/LeafRelief_Remodel.shtml
why do you have to cut around the hangers?
i have it on my house works great, no notching
Take the gutters down, take off the hangers, and install (new install) leaf relief on the gutter and re-hang. With the new install leaf relief you dont use a bracket you just screw through the back edge of the guard.Just to be clear I have Alcoa strap hangers that are attached with two roofing nails driven directly into the sheathing. Can I change these hangers to a different style without removing the entire gutter and then use the leaf relief retro TP5300? I never liked the look of the strap hangers. Whats the best hanger to use? I think I have 2x6 fascia boards behind the gutters.
I dont... I absolutely hate it. My installers hate it. My Alcoa rep doesn't even mention the word leaf relief with me ever.i thought you didnt like that detail Patrick?
Did you use the "retro fit" or the "new" system? If Retro which hangers?why do you have to cut around the hangers?
I have some Hangtite No Clip samples coming my way. I hope they will work with the Alcoa "roof apron" (drip edge/rear hanger)I don't know it's a good idea to screw through the roof apron then into the gutter. I hate the strap hangers, when I remove them what kind of sealer should I use to repair the nail holes?I use "Hang-Tite" from Ray-Tec Manufacturing.
Very strong hangers.
Sorry, no website link available for them.
They sell all sorts of gutter accessories and flashings too.
Ed
how old are your gutters? Might be cheaper and easier just to run new gutters and guards that's usually what we do. It takes too much time to mess around with the old stuff.Update: I talked with the Alcoa rep and explained my situation and here’s what he said. Your gutters are 5” using a “fascia apron” that the rear portion of your gutter hooks into, and the front of the gutter is supported by a strap hanger (#OG111). With this gutter system you need TP5300 retro. To install Leaf Relief on existing gutters you cut and remove the strap hangers and replace them with Leaf Relief hanger #OG13LR5.
These special hangers will cost me $1.58 each. I asked him if I could use a hanger like the Hangtite hidden hanger ($.15 each) and he said YES, BUT I would be eliminating the ability for the system to float because the hanger screw would go through the fascia apron and the gutter. Do you experts see this as a potential problem? I don’t mind using the Leaf Relief hangers, but I’m concerned about their strength because they hook onto the front of the gutter and just slide up behind the apron. No fasteners are used with the Leaf Relief hangers.
