1 - 8 of 8 Posts
General Contractor
Discussion Starter #3
Eric - nice work.
I am looking to become a Working-Dealer for AKW here in Western Oregon. Currently, I am a general contractor doing about any kind of work I can get, however after obtaining my CAPS certification and talking with AKW I am looking at specializing in Aging-In-Place type modifications.
I was inquiring to hear about other's experiences working with AKW. It is good to hear you've had success with their products. Did you use the Tuff-Form floor? Then it looks like you put vinyl over the Tuff-Form, I had not thought of that. Only considered tile.
Thanks for the pictures.
Making Things Accessible
I had a lunch meeting last week with Kevin Kahmann, founder of Beyond Barriers, who was bought by AKW. He's the guy behind the line. Apparently, AKW is going with a few distributors nationally and contractors will have to buy their product from the distributors. The contractor/dealers will have to invest $5000 into the product line. This is really tentative but that's the basic structure which could change. The $5000 committment isn't much if you're doing more that 3-4 showers per year.
Yes, that's the Tuff Form in the picture. I went with the heat welded sheet good over top which also is water tight. Between the Tuff Form water barrier system and heat welded flooring, there shouldn't be any problems with leaks. I stayed away from tile on this job due to maintenance/cleaning.
The AKW product line is good but expensive. The Tuff Form allows you to save money on the shower construction but the other products are expensive (but good) in comparison to the alternatives.
Was the investment of $5,000 worth it?
I have a similar situation in which I have been asked to invest $5,000 and see a good upside. I would like to know about a year later how your experience has gone and if you would do it again? All info is very helpful. Thank you
When I posted that thread, AKW was trying to sell $5000 kit/committments to contractors but that program is now eliminated. If you want to do an AKW shower, send me a private message with your phone and I'll help you connect the dots. Gotta run.
thank you for the quick responce
My situation is not about the showers or AKW but involves Kevin. I just wanted to make sure he delivers on promises and is good to do business with.
AKW Tuff Form Shower Pan
Thanks for the pictures Eric. I am chatting with a few builders online and trying to get more pictures of the install process. I would like to see how the drain cnnects to the waste line.
I can find no pictures with the unit tiled online.
I would like to see pictures of the waterproofing process and the flood testing procedures.
How does this shower base get flood tested?
I have contacted "Head Office" in Belgium and am waiting for more information.
Any insight would be great.
Have you used this shower pan in the center of a room before and pitched out from there?
JW
By Any Design Ltd.
North Vancouver
(604) 506 6792
1 - 8 of 8 Posts
