G
Guest
·Well I finally had enough of this hot weather and lousy AC in the house so I figured I would check the air coil to see if it was dirty. Having pulled the cover off it was clean but I believe the A-coil is installed backwards (this is a newer house) I have a 3 ton Lennox with the air handler in the attic , the handler installed horizontally. Anyway the air flow is like this ......
air flow-------------> < A-coil like this(closed end getting air pushed through it
shouldn't it be
air flow ------------------> >coil(open "/\" end recieving the air flow
shouldn't it be
