1. Clean the block, use clean water and a good scrub brush. Some mild muriatic acid isn't too bad either. DO NOT APPLY ANY SEALER if you want to apply stone. the sealer will prevent the mortar from bonding.
2. Use a premix mortar and add some bonding agent to the mix, this will help it greatly to stick. Buy a bag of type S or even Portland cement as well and add a shovel or so for each bag of mortar you get. This will make it stronger and a bit stickier
3. Same mortar can be used for the joints. I wouldn't worry as much about the bonding agent or the added cement
Biggest tip is if it's near grade and you get any snow or possible water build up try to joint the bottom of the stone as best you can.. You CAN apply sealer to the stone after it's installed, but it's not something I do so I can't recommend any products
