why would they want a dent in their new floor?i don't get it
why install a damaged peice of flooring?
who do you think should pay for it?
To your first question...they don't want the dent...that was kinda the whole pointwhy would they want a dent in their new floor?i don't get it
Thanks for that...I should have filled the nail holes, especially after she mentioned them the first time which led to my explanation days ago before she got amnesia.Another CLASSIC example of why I don't do prefinished floors much..You should of filled those top nail holes asap(know your customer)..Get someone really good to take out that dented board and replace it.One small dent in a 1000 ft job is pretty pickey but ya can't argue with the H/O if they see it...I could go on... but I gotta go to work!!Good luck..
I would not have top nailed the first few rows. We measure off an exterior wall , pop a caulk line. Then we screw a straight 1x4 to the subfloor with tapcons on concrete . Thats our starting point, it keeps the floor straight though an entire house.
Bingo.Bad spot there.
Two possible solutions.
Hire a furniture repair man from the nicest high end store you know-A top guy is a magician with a shellac stick.
If you have a plank of exactly the same size-Cut the center of the bad plank out with a skill saw.
Chisel away the shell that remains.
Remove the bottom of the groove --then glue in the piece.
I haven't done hardwood in years,however that is a common practice.--MIKE--
Other guys who do this day in and day out might have other suggestions. I would recommend AGAINST water, as stated above. You can get a scrapper with blades at most flooring supply stores, but you run the risk of nicking the wood - those blades are sharp. A drywall knife is probably a pretty good tool for this, but if you are having a LOT of trouble, and the wood looks black even after you get the pad up, I'd call a local guy who sands and finishes.this is kind of on the subject of needing advice.im not a flooring man but a mason contractor.i am remodeling a house for myself.when i took up the carpet yesterday,the hardwood floors beneath it are in very good shape.my problem is the pad is sticking to the hardwood.i am using a sheetrock knife to scrap it,but it is a long process.it also is only thing that doesnt seem to scratch the floor.
someone told me to use some water to loosen the pad.any advice?
