M
Mike F
·Guest
Okay, the situation is we have added a big whirl pool tub, a vertical spa 2 person shower, and the 50 gallon gas hot water tank is just not cutting it.
Do I replace it with a 100 gallon tank or just get a 2nd 50 gallon tank? I don't even know if it is possible to add a second tank, how would that work? Would it be connected in series to the original, so that when the original tank draws down its supply of hot water, instead of fresh cold water refilling it, the 2nd tanks hot water would refill it? Instant hot water systems are out of the question.
Any serious pros or cons to doing either one?
