You missed the point, which i mentioned in the OP. Several of the findings are fair and need to be corrected. 3/8” to the top of the switch is dumb. And it’s not the contractors fault, the construction drawings probably showed 48” to the center … blame the archy.And an attitude change toward the ADA is in order here also. These aren't mere code violations, this is civil rights law. The building code dictates the position and size of your business's sign out front. Civil rights law keeps you from putting "Whites only"on the sign.
A professional contractor has an obligation to know and obey the rules. I don't wanna hear the whiney-boy hacks that don't.
Yu no we can’t be readin and rithmaticin in Missippi vary gud.You need to do a bit more research. The coffee in question was not at the machine manufacturer's recommended temperature. The woman offered to settle for her hospital bills, but some dumbass at Mickey D's decided to f$%k with the wrong little old lady.
Again, it's a professional contractor's job to know what he's building. Architects can and do draw any damn thing and never get a red tag. If you don't have the balls to stand up to a client or architect when they're screwing up, you aren't going to last very long in this business.And it’s not the contractors fault, the construction drawings probably showed 48” to the center … blame the archy.
No it’s not, the gc should build what’s on the plans. That’s why you hire a licensed design professional. Like Thom Paine said … he always shows centerline height. Probably everyone does. Except the scumbag lawyer for the equally sh1tty client who says it’s 3/8” too high because of a strict interpretation of the definition.Again, it's a professional contractor's job to know what he's building. Architects can and do draw any damn thing and never get a red tag. If you don't have the balls to stand up to a client or architect when they're screwing up, you aren't going to last very long in this business.
👍🏻 Blessed are the peacemakers@Kowboy #25
@Half-fast Eddie #27
Gentlemen, gentlemen......
You are each correct in your respective perspectives .....
Often, others' interpretations, outside our individual influence, dictate
circumstances. Most of us might share a story of an asinine
interpretation of a code.
Sometimes we must push back; sometimes we must accede and
"keep on keepin' on"
Make a great day !
The coffee issue is correct, apparently the woman sustained 3rd degree burns when the paper cup dissolved when she had it nestled between her crotch (which was a stupid place to put it) but the rest of this post is a bunch of hogwash.You need to do a bit more research. The coffee in question was not at the machine manufacturer's recommended temperature. The woman offered to settle for her hospital bills, but some dumbass at Mickey D's decided to f$%k with the wrong little old lady.
I added numbers to your comments. 1 is wrong, it was created to assist handicapped people get around buildings and such. 2 is correct, but lawyers find gold everywhere. 3 is wrong. The ADA code/law has no teeth, no enforcement power. Cities will refuse a permit or CofO if you don’t comply with the code, but unlike a speeding ticket they have no power to fine you. It takes a civil lawsuit to punish the building owner. Theoretically a complaint is filed and the owner corrects the problem. Unfortunately the lawyers have fast tracked the lawsuits. And the courts don’t throw them out.1. The ADA laws are specifically designed to punish people and 2. are a gold mine for lawyers which is why they are so intolerant. 3. If the goal was to provide a service to the handicapped then the first rule would be an opportunity to fix the problem(s)
You're an absolute idiot if you follow this advice. I've seen winding stairs that could not be built to code as drawn. So go ahead, whip out your beloved plans and show them to the inspector as he red tags you. I'm sure your archy is going to reimburse you for the rebuild.No it’s not, the gc should build what’s on the plans. That’s why you hire a licensed design professional.
1. If it was created to assist people then it would have specifically been written to give an opportunity to correct the problem and also would be more flexible, would have had ranges to comply instead of being so absolute and also wouldn't have been so complicated. It's designed to screw over the design and construction industry by creating another gold mine for lawyers.I added numbers to your comments. 1 is wrong, it was created to assist handicapped people get around buildings and such. 2 is correct, but lawyers find gold everywhere. 3 is wrong. The ADA code/law has no teeth, no enforcement power. Cities will refuse a permit or CofO if you don’t comply with the code, but unlike a speeding ticket they have no power to fine you. It takes a civil lawsuit to punish the building owner. Theoretically a complaint is filed and the owner corrects the problem. Unfortunately the lawyers have fast tracked the lawsuits. And the courts don’t throw them out.
I'm on the design side these days. We sub out the ADA stuff to a specialist, it's too dangerous to touch it, too easy to get screwed by this malevolent system. Everything on this thread is backing up that decision. Incidentally I think it's California who has somewhat come to their senses and now allows a range that systems have to fall within, think it's Cali that does that now.Rio:
Familiarize yourself with the drawings and specifications of the jobs you do and know the ADA and local codes, and I promise you, you'll never have any trouble with either.
Pfffttt. It's a binder with some simple easy-to-read-and-comprehend dimensioned drawings in it. Geesh.We sub out the ADA stuff to a specialist, it's too dangerous to touch it, too easy to get screwed by this malevolent system.
Right. They have done a very good job of providing clear guidelines.Pfffttt. It's a binder with some simple easy-to-read-and-comprehend dimensioned drawings in it. Geesh.
