So … we’re on another initiative at work to discover and correct ADA accessibility issues. Witch hunt is more like it. We have engaged an outside architectural firm to survey the properties and create a report on what isn’t right. Then i get to make corrections.
Some findings are real and understandable. No problem there. Sometimes we get busted cuz the occupants have moved a trash can into the accessible path. Or in the restroom where they have a case of TP in the corner and it overlaps the lav clearance area. The consultant applies no common sense: if it’s wrong it’s a violation.
And this is one of the things i have to correct. ADA reads that the max height of a light switch is 48” … so this is a violation.
