1 - 11 of 11 Posts
If a wall is constructed of 2x4 with 1/2" drywall on both sides, what is the actual thickness?
Since everything is nominal I'm not 100% sure. My guess is: 4" actual thickness. Or is 1/2" drywall actually 1/2"?
The wall is 4 1/2" Grumpy. 2X4 as we all know is 1 1/2" X 3 1/2". And 1/2" board is actually 1/2".
G
Actually...standard door jambs come in 4-9/16" for 1/2" drywall. And that doesn't always work perfect as some 2x4 stock is 3-5/8", plus figure that the drywall is not always dead tight, and the fact that drywall has to finished with mud, which can vary in thickness.
Unregistered, where are you buying 3 5/8" 2by's? I'd quit shopping there.
G
Um...For sanity, Boardslinger is correct. For arguement sake...lets say you did come across a 2X4 that was 3-5/8, Don't use it. But, if by some slim minute chance you do find one and it is being used, and you can't manipulate that 1/8 of an inch in your installation, come back to the boards and we'll help you out =)
On the other hand. No house is the same, especially when it comes to the older style homes and the even older homes that actually have 2"x4" studs not 1 1/2x3 1/2 studs. But that's where experience and knowledge come into play.
The last time I got hit with a 2x4, it was swung by my mother in an attempt to stop my brother and I from killing each other, this was about 7 years ago and I forgot much of what happened that day and for a few days after.
This is why I want to change the policy and make everyone register to post.... I can't tell who is saying what.
I am a trim carpenter and I rip all my cased opening jamb at 4 5/8". This covers any inperfections in the wall will sheetrock mud. Stock jamb comes 4 9/16" and I found that this is never good enough. I always wish for that extra 1/16".
Sunnyholme
1 - 11 of 11 Posts
