41 - 56 of 56 Posts
Discussion Starter · #41 ·
what do you guys charge for the scaffolding,
we add around 2 bucks a sq. ft
I don't have a set price for scaffolding ( though I probably should) I just figure how much scaffolding I'll have to do on a job, and how long it'll take, and just wrap everything up into the estimate.
Have Trowel, Do travel
When you say $2 a sq ft, do you mean, you add $2 per sq ft of the wall you're building....don't quite see where you're coming from....
sq.ft. for the scaffolding,
if I need to build 400 sq.ft of scaffolding to do that chimney,
I add on 800 dollars to the costs.
Discussion Starter · #46 ·
Top courses around these parts need to be solid or grouted to prevent termites from undermining the sill...not a problem down there?
Looking good!
Down here most people use a solid cap block. If they don't ,they have use metal flashing between the block and plate.
Discussion Starter · #49 ·
If I have to go 3 scaffolds high or more, I usually go 3 wide. More stable , and makes me fill better. :laughing: But it gives us more working area. I saw my pieces up there, and we stock our materials up there ,too.
mason contractors
putt logs
have you ever heard of putt logs or used them for block basements?
about 4' long 4x4's with 1/4'' x 1-1/2'' 4'' long plate steel extending out of one end.It inserts into the block vert joint.The other end is supported by block on end usually 2 for a 8' basement. Very nice and fast no braces in the way etc. They are also nice to use on a inside corner when the pipe staging is too long [wrong x braces]. They even can be inserted and bent a bit. Good on stone walls esp rough terrain.
I had a boat load had to scrap half when my father passed about 5 years back due to the barn being sold.
I bet you guys never seen 5' masons horses? Before pipe staging they were used. The top was longer than the base stance so as to be stackable. I never seen them in use but I cleand the barn out- around them as they took up much space.
Nice blockwork kido! I remember using the 3 cell 12's ....the forms would wear and they would end up 7-1/2'' high.....pain in the but good for the duro wall course ..like jb said they were a tad long too!
If its up there we will run a couple 2x4's into the house, nail them to the planks and let just a little down on the front screw jacks. No wiggle, 1 tower. We bolt it to the house after 6 high but still use 1 tower.
Discussion Starter · #53 ·
I have this set of scaffolds wired at the eve. We take eye screws and screw them into the rafter tails, and wire it to the frames.
it's amazing the difference a bit of tension can make to scaffolding, bracing against the building, then tying into it and a 40' lift of scaff goes from feeling like you're out at sea to feeling like terra firma
Discussion Starter · #55 ·
I had a guy helping me a long time ago, and that sucker would strut like a cartoon cat! When he walked across the scaffold, everybody would hang on.
After trying to reteach him how to walk......we made him the lift driver! :thumbsup:
41 - 56 of 56 Posts
