Here's a look into the hallway, - - I have a header (turn-board) at each end to be symmetrical and so I can have a starter to run that room at the end of the hallway diagonal again (same direction), - - the other room off to the side will more than likely get run parallel with the hallway, - - the slowest part was fitting the last lengths running to the turnboard at the end of the hallway, - - you had to cut them to exact size and cut in new end-grooves . . .
