90 minute mud
32K views 38 replies 14 participants last post by  JAH
#1 · (Edited)
I have a tight deadline coming up on an office reno. I need to move a door opening and finish it asap.
Is 90 actually dry sandable in 90. I assume that means light skim coats.
I was reading the bag
Its says on the bag on the reverse side in small print, sets up in 90 but is sandable next day.
I'm confused.
I always thought a hot mud mix would let me sand in 90 and keep rockin till I'm happy with the finish.
Thanks
#3 ·
What he said.
When we have to get a patch done quickly, we use Durabond for the fist coat. Then Easy sand for the rest. I usually get 45 minute mud. Sanding would have to be done the next day.
Even with the 45 minute mud, there is some variance in setting times. If we used it all the time, we would probably be better at mixing it to get consistent setting times.
#8 · (Edited)
How tight? Is this a same-day job?
I could see getting the first coat on in the morning, heat gun to dry it fully, then the follow-up coats will be quick and easy. Note that it may look dry from the gun, but moisture may reappear as it gets to the surface. Watch for that and keep at it. Vigorously mix your first coat and it might just dry out in half the time for you, too.
Edit: and keep your sanding to a minimum...that's just more compound to dry anyway!
#22 ·
The couple of smaller knives I tape with are stainless steel and my bigger finishing blades are steel.
Im guilty of not always mixing or thinning. I am usually bouncing between jobs and tasks. not fully focused on just mudding. The jobs I know Im taping and mudding all day I mix and whip nice. I even keep a bucket of water around to dip my knife in occassionally. I get nice edges on those jobs. Its is a big diference.
Today I used both medium and AP. The medium is was wayyyyy to stiff.
#25 · (Edited)
my six inch knife is square and probably 20yrs old. Since the beginning i have always grabbed this knife. Its really a favorite. Its way due and has a nick but i sanded the edge smooth. Lol i only like round shaped knifes on smaller 4" knives.
20 years?? In drywall years that's like ....110 !!!
#30 ·
Tom, if you're just going to grab thinned or unthinned and start working, you really need to consider having two sets of knives to handle the different amount of pressure you have to use.
Knives and rollers are cheap. If you aren't replacing your knives with some regularity, chances are you're doing way more sanding or taking way more time detailing than you could otherwise.:no:
#32 ·
My issues seem to stem a lot of times in patching old to new drywall.
The old drywall was a full 1/2 thick plus the added mud and it seems 5 coats of paint. The new lightweight that is only left now is closer to 3/8 than a 1/2.
Its a dam nuisance working with it to get it to match the existing finished walls.
#34 · (Edited)
YIKES
I went back to get the finish coat on after cranking up the heat to 85 and running 2 fans on the repair. The paper seam tape cracked on the one edge that was on the painted side of the wall I feathered out on the 3rd coat of reg. mud. The joint itself is fine. The tape was fine after the second coat of reg. mud.
My guess, dried to fast and shrank. would that be a good assumption.
Do I seam that now and re feather it or maybe cut the tape back a bit and feather it out. 1st coat was 90
God It was really rockin along with the advice I was getting.
