1 - 20 of 88 Posts
Punching above his weight
Got asked to put up some 7" prefinished crown.
I could use some pointers on both the hugeness and the prefinishedness, as I don't often deal with either and have never done both at once.
I like doing butt joints for seams and coping my corners. Any reasons I should stray from this?
Also, what do you guys do for blocking on stock this big?
We're gonna need a bigger boat.
Easy Gibson said:
Got asked to put up some 7" prefinished crown. I could use some pointers on both the hugeness and the prefinishedness, as I don't often deal with either and have never done both at once. I like doing butt joints for seams and coping my corners. Any reasons I should stray from this? Also, what do you guys do for blocking on stock this big? We're gonna need a bigger boat.
Pre finished is always time consuming. Take your time, make sure all your blades are sharp and get good a splitting 16th's in your measurements.
How many linear feet?
I'd use a 2x2 or 2x3 for nailers - but make your own from 2x4's or 2x6's... I've never seen a 2x2 or 2x3 that was worth a chit. Depending on your spring you might even want to stack 1x's to compensate.
Truth be told I've never done a true 7" crown in one piece. Good luck If you go through with it!
Thanks for the responses.
If I do this I'm going to have to either rent or buy a new saw. I don't have a slider so I can only handle 5 1/4 max and I cut it angled.
Linear footage is roughly ~150? It's a lot of work. Only one outside corner which is nice, but there's 4 22's.
I've biscuited my joints before but it's extremely time consuming and I didn't feel like it yielded results that were much better than I can get from just nailing solidly after lining my joints up by hand.
This would be for a guy I've done a lot of work for but who keeps insisting I work hourly on this current job(complained about this one in other threads). There's no way I'm doing 7" crown hourly.
Ok, one last laugh. I was painting this place a couple weeks ago and while I was there a hangaround from the GC crew that built the place was there supposedly doing punchlist work but really was standing around talking to me. He kept asking me questions about my technique or what have you. Acting like a big shot. Then he asked who was doing the trim. Told him I probably was. He said, "Oh yeah, probably do this in two hours, right? What do you charge, 50 an hour? Probably more for something like this right? 75?"
I just stared at him for a minute then said, "So you're saying you'll put up this crown for $100? You're hired."
What a maroon.
I wouldnot recommend butt joints for this. Glue and a 22 degree scarf joint. If you have a 22 gauge micro nailer, use it to "stitch"your joint. If you are buying a new saw, also buy one of these for this project. You can get a Hitatchi reconditioned for about $100
Administrator
Sawdust follows Me Everywhere
I did 8" prefinished crown with my 8" Hitachi slider. Not really that fun. Came out beautiful though. With crown that big 0.1 degree will make a difference.
1 - 20 of 88 Posts
