Kelly I blast boats all the time with soda and crushed glass .... Last year I did a 70's vet and wondered if the 30/60 crushed would work, the guy that owned the car new me well and let me try a area to compare, In my option the soda was the best choice leaving it fairly smooth, fibers showing The glass did work ok, but left the surface a little pitted, but not to bad at all. I tried to pit the pictures on but it's hard to see the difference, first picture is soda, second glass and the last one is soda Just a note: low low psi - around 50-60 psi Like painting start blasting away from the surface and then move into it. If you start dead on you will get creators I'm the fiberglass . The fiberglass does not have a gel coat like a boat and can burn up fast Try a area under the car first to see what it looks like then move to the body
So I guess you can't see much of a difference in the picture and like a said it's not bad with the glass it's just that the glass cuts quick and you have to be really carful not to hit a area to much
The painter will have a little more work to do but he will be fine lol
