1 - 20 of 179 Posts
Looking to cut couple hundret shets of plywood
And would like to use makita 16" beam saw for that purpose or similar saw does any body can tell if the saw will have enought power to cut full depth ..... at 13 shets of 1/2 each...?
Or wormdrive will do better job...?
Track saws have smaller capacy and have less power...
Chainsaw makes too rought of a cut
Remodel
I always looked at cut roughness and cut accuracy as two different things. If you get a too rough, but accurate cut off of a stack, you can sand the edges, but that's extra time.
Whether you can power through the cut or not is going to depend a lot on how much binding you're getting - bottom of the stack could be a problem.
Discussion Starter · #16 ·
Yes you are right those are different I need accuracy. ..
Always Learning
Just one cut per sheet? For me, back delivery truck into shop. Unload bunks with my forklift. Move bunks one at a time close to my shop table saw. Make cut, re-stack on another pallet. Repeat till done. If you dont have the setup, see what you yard will charge you to pre-cut them. Thats alot of sheets to cut...
1 - 20 of 179 Posts
