5 inch Sanding discs
2433 Views 5 Replies 5 Participants Last post by  #1 Handyman
Does anyone use the carbide sanding discs for orbital sanders from Dura-grit or the carbide sanding block? Working on some red oak for stair treads and the 120 grit on regular sanding discs for the 5 inch orbital just does not last.
1 - 6 of 6 Posts
theres this tool company called Festool, they have great paper. The sanders are ok too.
Never heard of them. Are they any good?
over priced mostly. look a little boring next to my black and yellow dewalt gear
Go to your auto parts store and buy the 3-M Gold sanding disc. Don't buy the cheap imitation crap, get the 3-M.
I use to sand down the raw hacksaw cuts on fiberglass sail battens using a carbide sanding block. It was the the only thing that would last more than two battens. Forget using any type of sandpaper.
My Findings:
Because there are a lot fewer grit particles and they are placed further apart (there is a lot of dead space) you should get a smaller grit than you would use with conventional paper. That is because they tend to live a rougher finish.
1 - 6 of 6 Posts
