When you doing a sewer connection typically, you have a starting elevation and ending elevation. Then you determine your pitch by measuring the difference in elevation between start and finish points and divide the number of horizontal feet of run into the number of inches of fall which will give you drop per foot. On the sewer pipe the drop should not be more then 1/4", because if your have to big of a pitch, water will run faster then s^*t. Suggested pitch for 4" pipe is 1/8" to 1/4" per foot...especially now its important not to have a big pitch, because this day and age you can use a 3" pipe from the house to the curb.
