32' clear span LVL???
21K views 29 replies 15 participants last post by  Nowhere
Hello everyone, as you can see I'm new here. My name is Erik & I have a question concerning the load capability of a doubled up LVL system.
So I'm working with a customer that wants a 32'x32' cabin, & he insists on a clear spanning roof ridge. My roof construction experience is limited to trusses mainly, aside from the occasional hand framed screened porch or gazebo roof. I have no working knowledge of live / dead load calculations for roof systems. My question is this:
Will a double 1-3/4" X 14" X 32' LVL provide sufficient load support as a ridge for an 4/12 pitched roof?
#13 ·
That's great that you guys can get a beam calc'd for you.
What about the rest of the stuff that goes with it?
Footings, hold downs, seismic calcs, shear wall calcs. hardware for post to beam connection, rafter connection....etc....
We can all likely guess as to what it takes, but I am not hanging my azz out liability wise without having a set of stamped drawings and a permit.
For you guys with little to no involvement with plans, specs, engineering & AHJ's you have it easy to an extent.....
But, wherever you are without any of the above...I'll guarantee you there is a lawyer and a judge not very far away.....
#21 ·
I'll have to agree, He needs to tell this to his architect. Then said architect can hand you over the stamped plans to build. :thumbsup:
Is he asking you to design and engineer it:no:
#26 ·
The quadruple 24" LVL was among the dumbest **** I have ever done, I think. It was a change order to replace a double 11 7/8 to get rid of two posts, for a future pool table. We rarely do stick framed roofs for the company I work for, but we have done a 34' lose bearing ridge in one house, but the rafters landed on walls upstairs, I wasn't involved with the figuring on that job.
#29 ·
Now we're getting in to non structural ridge and all the misinformation that always comes with that.
Collar ties are not prescriptive code. Ceiling joists are. Must be in the lower third, and they have to be on every rafter, and at low pitches like that they might need more nails than the wood can handle. 14-26 nails at this slope and span depending on snow load, if they're on the plate. More if they are higher. Also there isn't any ceiling joist in the prescriptive tables that spans 32 feet, so it needs a king post to hold it up. Then it's an engineered solution.
No matter what, this is engineered, but it's not that hard. A big glulam, attached to big posts that go to big footings.
