Do masons usually wire ceiling fans? :whistling
Two remotes, same channel.
If this statement is correct, you cannot do what you want to do. As soon as either 3-way switch turns the power off, the remote & fan have to power to operate with.........so how can i incorporate a 3 way circuit to operate the light and use the remote to dim the light and operate the fan portion. ......
I just did this in a home about a month ago with the exception of it being a 4-way. Just install the receiver as normal except do not use the light circuit on the receiver. The light circuit "from switch's" should be wired directly to the lights in the fan. You will be using the receiver/remote for the fan only. So far it has worked fine. The light comes on from the three different locations with the fan off, the fan works with the remote on all speeds with the light off. Obviously they all work properly together.
Switch 1 & 3 would be called "three way switches"If they are wired anything like UK then you would need a 2 way - intermediate - 2 way then of to fan/light.
I dont know your exact terms for them kind of swicthed over here.
I still maintain it won't work, even with 3 wires going to the fan. One original wire will be for the fan, the other for the light.OP didn't state if the ceiling fan box has 3 wire run to it.
You idea would be fine if it does.
Switch 2 would be a "four way switch"
Don't ask why they are called such. :blink:
Personally, I think it's a throw-back to the old knife switch era. In reality, 3-ways are just single-pole, double-throw switches. And the old SPDT knife switches would basically be 'center off'........... Funny why they call a switch that has only 2 ways to switch a 3 way :blink:
Oh i see. I aint looked for one yet but do they do 1 way switches over here?
We're goofy on this side of the pond.Im in the US now. Used to live in UK
We call 1-way switches single-poles, and we drive on the right side of the road.
