1 - 7 of 7 Posts
So I'm doing a pretty big renovation ( 3 baths, 120 sq' of tile (laundry rm) and approx. 1,200 sq' of hardwood. About 40 sq' of it is 3/8" engineered hardwood for the powder room that was existing and I am ripping it out due to some water damage. Issue is I've only done 3/8" in a glue down scenario and my Bostitch flooring stapler is to big for the 3/8". On top of things the floor which carries out from the bathroom throughout the kitchen and foyer area, was previously installed over top of laminate & sheet vinyl. So my question is do I need to purchase a stapler that I can use for the 3/8" or could I get away with shooting 16 or 18mm gauge nails through the tongue along with a little liquid nails on the bottom side?? Any other thoughts or suggestions are welcome.
Thanks in advance
Yeah, you need a smaller gun.
x2 on the glue.
On a tiny area 40'sq you could always just blind nail with a 15 or 16 ga finishing nailer.
Just be careful when you place the tip angled on the tongue you have it set just right and dont chip the wood face.
just finish 800 sq ft.
I brad nailed the whole thing 18g but didn't glue. Am I in trouble? Use a bostitch. Ill never consider working with 3/8 again. I thought the process took way to long to bid it right. Plus setting it into place and then nailing felt like doing a pergo and hardwood floor at the same time.
Paul
Gluing it would have made way more sense than that. The time alone would have made it worth the cost of adhesive.
1 - 7 of 7 Posts
