Is one better than the other? Will it help with insulation?
mdshunk said:Depending on what "zone" you are in, and if the IECC is enforced as part of your building codes, you may have no choice but to build with 2x6 for the added R value. That's the way it is in my area.
That's not a humble opinion. That's a factual statement. No doubt.wbsbadboy said:And then there is also the ICFs' that can be used. No wood at all hardly. But IMHO a serious pain in the ass to work with.
EIFS?wbsbadboy said:In addition to the high density insulation there is another method to meet the required R factors. There is a styrofoam paneling that you can put on the exterior of the building and then stucco over that. Im not sure what it is called as I stick with 2X6 walls. Much stronger and most of the seismic hold downs require it. And then there is also the ICFs' that can be used. No wood at all hardly. But IMHO a serious pain in the ass to work with.
Not the fault of EIFS, sounds like the HVAC wasn't designed properly.ContractorSon said:EIFS?
Have heard rumors that a certain high-end apartment building in Cleveland where some of the Cavaliers spend their "post-game" evenings is making them sick.
Covered with EIFS... Allows no moisture escape/ventilation whatsoever.
Yes,ICFs are also difficult for trades to work with,but very strong.
Because heat rises, most of your loss/gain is through your ceiling/roof. Because much of your exterior walls are windows and doors, much of your wall space is unaffected by the r-19 vs r-13 difference.
Sure, the r-19 saves some pennies, but why not look first at the dollars?
2x4 construction with styrofoam exterior gives you the insulation that you are required. The benifits are that the transfer of hot and cold on the plates and studs is reduced. This form of construction would surpase any convential 2x6 construction when calculating heat loss or gain. Not so when concerned with wind shear, the 2x6 structure is going to fair better.........14 percent of a 8 foot high wall is dimensional lumber with limited R-value.I'm shocked by this...c'mon...what stud size....does this affect insulation...2x4 vs. 2x6???????? Cardboard or plywood to sheet a roof, extension jamb a window.....here it's 21/42 .....even in dryer/hotter areas benefit from better insulation.
2x4 walls are unheard of for ext. walls, in this area at least. Geeeeeze.......I'm dumbfounded.
