Don't freak out if you're building a new, seemingly middle grade house, and the electrician is mounting two panels.
Some of you may be used to this already if you normally build large houses that are getting 320 and 400 amp services, but this is becoming common even in modest homes with 200 amp services.
The reason is this: The NEC limits each lighting and small appliance panelboard (the category into which residential panelboards fall) to 42 circuits maximum. For this reason, the panel manufacturers have limited their boxes to 40 or 42 spaces, depending on the brand. Your typical new one story 3 bedroom home with unfinished basement will often have the following circuits:
1) Kitchen countertop circuit #1
2) Kitchen countertop circuit #2
3) Refrigerator
4) Dishwasher
5) Microwave
6) Living room receptacles
7) Dining room receptacles
8) Outdoor receptacles
9) Garage receptacles
10) Freezer
11) Sump pump
12) Bedroom #1 and #2 receptacles AFCI
13) Master Bedroom receptacles AFCI
14) Bedroom lighting and smokes AFCI
15) Master bathroom
16) Main bathroom
17) Whirlpool tub
18) Kitchen, Living room, Dining, hallway lighting
19) Basement lighting
20) Basement receptacles circuit #1
21) Basement receptacles circuit #2
22) Clothes washer
23, 24) Range (2 spaces)
25, 26) Clothes Dryer (2 spaces)
27, 28) Hot water heater (2 spaces)
29, 30) Air handler circuit #1, blower and controls (2 spaces)
31, 32) Air handler circuit #2, backup heat package (2 spaces)
33, 34) Heat pump condensing unit (2 spaces)
35, 36) Hot tub (2 spaces)
37, 38) Outdoor shed prewire (2 spaces)
39, 40) Swimming pool (2 spaces)
41, 42) Air compressor receptacle(2 spaces)
43, 44) Welder receptacle (2 spaces)
45, 46) Well pump (2 spaces)
You can see that this is more than one panelboard will hold, even though the demand load is less than 200 amps in many cases. For this reason, two panelboards are often mounted. Even if you didn't have all the items on the list (or substitute different items), the panelboard would be full or near full right off the bat. It seems prudent in that case to mount two panels for future needs.
3) Refrigerator
4) Dishwasher
5) Microwave
10) Freezer
11) Sump pump
15) Master bathroom
16) Main bathroom
17) Whirlpool tub
22) Clothes washer
