1 - 20 of 141 Posts
Administrator
Maker of Fine Sawdust
That's what that picture was.....(last one)
I like Green things
Discussion Starter #3
I told you they spun some big cutters on it, that is a cutter straight from the catalog/manual that came with the shaper.
I still did not find the RPM's but, by doing a little math on the ratio of the pulley size, it should spin right at 10,000 rpms, maybe a shade under.
Cool shaper!
So I assume that's a steel bit instead of carbide since it's an OEM bit? Bet that doesn't last too long before needed a sharpen :laughing:
I like Green things
Discussion Starter #7
Cool shaper!
I would think it was high speed steel.
The mill shop by my house only uses HSS, says it leaves a better finish but, needs a bit more attention vs. carbide.
I'm always a little worried about screw tightened cutters that could fly apart with
centripetal forces. But I do know that they have used those since the '20's, and Amana continues to make them. So I guess I just a little paranoid
I like Green things
Discussion Starter #10
I am already developing a fear of sharp spinning things, thanks for fueling the fire. I am not sure if I am going to buy knives for those or get new cutter heads.
Administrator
Should we start calling you three finger Warner or just Lefty?
Administrator
Nice $400 donation. Put a frame around it and hang it on the wall.
The problem with those multi-piece cutters isn't losing fingers, it's getting gut shot or worse.
My dad has a moulder head cutter for his old Sears 1/2" arbor table saw with replaceable knifes. I too scared to use it, could get a shot right into the middle of the forehead.
Administrator
That is why they have serrated cutter now. But those are pretty safe. If you feel a little nervous put some red Loctite on the leading edges where they meet the hub. Nothing is going nowhere if the nut is tightened properly.
I only get nervous when I am using a rub bearing on a 5" panel cutter spinning at 10,000 RPM. Hearing the noise, seeing the blur of the cutter just sitting there in open air is a bit concerning. I have a few other rather large cutters that I use rub bearings on that should put a bit of fear into you.
Construction Connoissuer
Can you get parts for that thing, that sucks.
Did you know it was broken when you bought it.
From reading other post on it,
I thought it was plug and play, just needed three phase.
I like Green things
Discussion Starter #19
I didn't know it was broken, I don't think the guy I bought it from did either.
I can get the whole assembly with all the rods, gears and such but, it costs almost as much as the shaper did.
1 - 20 of 141 Posts
