1 - 20 of 39 Posts
Anyone ever seen or put studs at 19.2 OC? Here residence is 16" OC and a garage can be 24" OC but I've only seen floors @ 19.2 OC, until yesterday. Was putting in wall ties and the garage wasn't on 16's or 24's. Wised up and found the studs @ 19.2. Never seen that before
Never seen it but always thought it was a pretty good idea... Only issue would be that I don't think they make fibreglass batts that size. Would be a good compromise between saving material, more efficient insulation and structural stability (I've found some 24" O.C walls to be flimsy)...
I've built two houses in the past ten years where almost everything (exterior walls, ceiling joists and roof rafters) were on 19.2 centers. Both had 2x6 exterior walls. I liked the fact that all of the joists tied into the rafters.
diplomat
I've never seen 19.2 insulation. Anywhere they use IRC you can use 24" OC in certain cases, like up to 2 stories with 2x6. IRC doesn't mention 19.2 for walls. I bet drywallers would hate it too.
Yes truss joists, are spec'ed for 19.2. Most good builders will still put them at 16".
Can end up as a pretty bouncey floor.
Never seen studs at that spacing though.
Builders don't want to pay for blocking in cabinet areas. I hate 24"
Someone told me that a long time ago. I was more asking then telling. I though it somehow worked it's way to metric or something. Like I said though, I've never seen it used. Everything we do is 12oc 16oc and 24oc
24" x 4 =8'
19.2" x 5 = 8' (doesn't work good with fractions.)
16"x 6= 8'
It Is just to save on material. :thumbsup:
There's an old company here that builds developments and cheap spec houses, that builds everything on 19.2 OC. They are the only ones around here that does it.
You know if you do any work on an old house, and everything is 19.2, it's a Town and Country house....
1 - 20 of 39 Posts
