So today i was using my 18 ga 2" oiless bostitch gun and it abruptly stopped firing and instead just blew air from the trigger .
I never had a Problem with this gun.. Only 1 year under its belt.
I took it apart and everything looked fine. Still had grease in the cylinder.. I pushed the cylinder and firing pin down put it back together and it began to fire again. Once i set the gun down for a few minutes it stopped working again. I repeated this process 3 times and it quit working every time..
Whats the problem?
My only though is that the cylinder is getting jammed in the head valve?
Whats the problem?
