12" scms blade for framing
2750 Views 6 Replies 4 Participants Last post by  Kent Whitten
Hey all,
I just stepped up to a 12" scms from a 10" and I am wondering what blade you all use for framing in your scms. I am looking at a 30 tooth freud and a 20 tooth freud. I am worried that the 20 tooth may be too aggresive for trim boards.
Here are the blades:
http://www.amazon.com/exec/obidos/t...c_mri?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
and
1 - 7 of 7 Posts
I dont think either of those blades are correct. They are both ripping blades for a table saw. What blade came with the saw and what brand of saw do you have. Try to find a cross cut blade or one that is designed for a miter saw.
Here is a link to a few blades for a miter saw.
http://www.amazon.com/s/ref=nb_ss?url=search-alias=tools&field-keywords=12"+miter+saw+blade
Matsush!ta heavy duty work horse.
Aww Warner, now you're talkin' my language. I love the Matsush!tas. I use the combo in my worm drive and it cuts like butter. I get them delivered to me from a store in CT.
I ran them in everything I have. Circular saw (just awesome), table saws, and formerly in my 12" bosch. They Heavy duty Workhorse one's were a thicker kerf blade than the rest of the line.
Unfortunatley, Matsush!ta has no plans to make a blade for my Kapex as of yet.
Have you ever tried cutting a 4x10 glue lam with one of the those negative hook angle blades?
The saw I bought is a Dewalt 718, it came with a 60 tooth combo blade. The blade is worthless because it cuts too slow for framing or siding and is too rough for trim.
I always used this blade with my 10" scms and never had a problem:
http://www.amazon.com/D1024X-Diablo...f=sr_1_20?ie=UTF8&s=hi&qid=1258419485&sr=1-20
That's good info. I didn't know they made a thicker blade. I tried one in my SCMS and it wandered badly because of the thin kerf.
I have a small 5-1/2" Makita saw that has a motor that turns 8000 rpm and I put the 36 tooth combo blade in it and that little sucker can make on heck of a rail saw setup. Maybe as good as those green ones :whistling
1 - 7 of 7 Posts
